 Winbond 25Q256JVFQ
stabio Posted - 11/25/2022 : 07:43:40
Anyone read with success this chip Winbond 25Q256JVFQ 16PIN? I was using Adapter ADP-098 but i can't read this chip :/
Photo:
https://imgur.com/a/1AX98OA
Cheers
ZLM Posted - 12/31/2022 : 09:22:47
1. Make sure you are using Re7.31 or later software.
2. Make sure the chip is correctly installed in the adapter
3. Make sure the chip orientation is correct in adapter.
4. Make sure the adapter orientation is correct in programmer ZIF.
5. Make sure the chip pins are clean and have good contacting with adapter.
6. Make sure the adapter has good contacting with programmer ZIF.
The 25Q256 chips are tested and should work on this programmer.
anniel Posted - 11/25/2022 : 08:45:25
Originally posted by stabio
Photo:
Cheers
Any error message in the log?
