 Fix Win11 update causes USB driver overwritten
ZLM Posted - 02/17/2026 : 12:08:09
The GQ-4x4 USB driver maybe over written by a conflict USB driver called "IOS Manufacture DXI Driver EEPROM - Missing"
under Windows Device Manager->Imaging Devices list
The driver need to be uninstalled in order to let GQ-4x4 load the driver correctly.
Here are the steps:
Step 1, run Device Manager and set it to Show all hidden devices.:
Step 2, click on Imaging devices list:
Step 3, right click on the IOS driver and select Uninstall/Remove the driver.
Step 4, the correct driver should be loaded.
vendtech Posted - 03/04/2026 : 13:34:07
Thank you so much, I have been going crazy trying to get this working. Now it is. Many thanks.
Janosch Posted - 02/17/2026 : 12:22:11
Thanks, that indeed fixed it. Awesome, thank you very much!
