 Confused about AVR ISP
tuc Posted - 04/30/2026 : 16:52:45
Trying to program an ATMEGA328P. I understand that this can be done with my GQ-4x4 by using an AVRISP. The problem is that my chips aren't in a device that can be programmed via ISP. What do I need to get to be able to program it? Everything I find is the programmer side, not the other side of the cable. Specific product names appreciated.
anniel Posted - 05/07/2026 : 10:59:04
Originally posted by tuc
IC clips usually come with everything needed otherwise you can use ADP-067 or similar.
I have an IC clip with no wires on it. Only clip. What pins on the clip go to what pins on the GQ-4x4
Follow the datasheet of your chip and match it to the software indications.
tuc Posted - 05/07/2026 : 09:45:53
anniel Posted - 05/06/2026 : 08:22:31
You need a PCB or a breadboard.
The PCB that this goes into doesn't have any programming points. That's why I'm trying to find out what I need to buy/breadboard. Is there a schematic or item I can refer to?
Put your chip on the PCB and simply use an IC clip.
Great, and what do I connect the other end of the IC clip to, and how?
tuc Posted - 05/05/2026 : 14:48:38
anniel Posted - 05/05/2026 : 08:13:28
tuc Posted - 05/04/2026 : 17:52:42
anniel Posted - 05/04/2026 : 07:37:31
Your PCB already provide the clock signal, you only need to power it and connect the five wires from the GQ-4X to the chip.
That's the thing, I don't have a PCB, as mentioned "The problem is that my chips aren't in a device that can be programmed via ISP. ". So I have only the GQ-4x4 and a chip.
tuc Posted - 05/03/2026 : 14:29:32
anniel Posted - 05/02/2026 : 05:35:36
Only power is required.
Why does everything I see talk about clock sources and things like that?
tuc Posted - 05/01/2026 : 15:30:15
anniel Posted - 05/01/2026 : 10:35:12
Generated in 0.4 sec. Snitz Forums 2000
