 GQ-4X how to write MXIC MX25U6435F
83Air Posted - 12/09/2015 : 13:04:08
Hi there
I have GQ-4X programmer and try to use MXIC MX25U6435F.
I did buy the appropriate adapters( ADP-099 and ADP-081a).
I don`t know which device to select(mx25u6435f is not on the list).
Any help is appreciated
datasheet
h**p://www.macronix.com/Lists/DataSheet/Attachments/3213/MX25U6435F,%201.8V,%2064Mb,%20v1.4.pdf
14   L A T E S T    R E P L I E S    (Newest First)
anniel Posted - 12/25/2019 : 05:31:19
Originally posted by pashha
I finally did a test on this chip with ADP-099.
However, there is a compatibility issue.
The only way to solve the problem is to modify the ADP-099.
Here is what I did:
1. changed R4,R5,R6,R7 to 100 ohm resistors.
2. added a 10uF capacitor on IC U1 pin 1 and 4. Pin 4 is ground, pin 1 is positive.
After modification, I successfully ID, read, erase, write, verify the MX25U6435F.
174563 bytes
it works! Thank you dear (By the way.. 100 ohm resistor is labeled with 101)
Thank you for your testimonial.
pashha Posted - 12/25/2019 : 01:02:06
Here is what I did:
174563 bytes
83Air Posted - 08/29/2016 : 02:37:31
I am sorry it took so long to reply.
The thing is it still doesn`t work, but that may be because i damaged the eeprom, when i was testing it without the adp-099 adapter, and i don`t have another mx25u6435f eeprom to test.
ZLM Posted - 04/09/2016 : 17:19:33
Here is what I did:
174563 bytes
83Air Posted - 01/26/2016 : 15:40:56
thank you
ZLM Posted - 01/26/2016 : 10:43:11
OK. This one I think the software need a tweak. I will request a testing chip and hen test it then. I will post the result here.
83Air Posted - 01/25/2016 : 14:30:00
ID checks ok without ADP-099 on mx25u6435f
83Air Posted - 01/16/2016 : 04:20:12
It took me a while to get another mx25u6435f to test, still does not recognize the device.
Any ideas ?
83Air Posted - 12/16/2015 : 01:22:44
I tried to test with both adapters(ADP-099 set to 2.5V) on a MX25l8005m and i worked, ID check ok(correctly recognized eprom as mx25l8005m).
ZLM Posted - 12/15/2015 : 12:34:36
There are many factors cause the ID fail.
Try to use another supported chip to confirm the adapter ADP-081 and ADP-099 work. Then we can focus on the software.
83Air Posted - 12/15/2015 : 11:22:29
no, ID does not work.
ZLM Posted - 12/14/2015 : 20:44:12
does ID work?
83Air Posted - 12/11/2015 : 16:38:52
erase appears to work
blank check fails
read appears to work
write stuck at 0%
ZLM Posted - 12/09/2015 : 19:03:33
Try :
Name="MX25U6435F",ID="C22537",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="5V",CodeSize="8388608",Adapter="ADP-081+ADP-099 adapter",Message="Make sure the ADP-099 is used. The programmer will supply 5V voltage. Without ADP-099, the chip maybe damaged.";
