 Someone could translate this?
anniel Posted - 06/16/2016 : 06:36:47
65856 bytes
74828 bytes
www.seekic.com/circuit_diagram/Sensor_Circuit/MN12C2010_Memory_Integrated_Circuit.html
anniel Posted - 06/19/2016 : 13:34:46
Thank you ZLM. Not much info for reading/writing the chip.
ZLM Posted - 06/19/2016 : 10:22:42
English version pin out:
91824 bytes
151755 bytes
anniel Posted - 06/18/2016 : 03:19:54
The MN1220 is a similar device www.datasheetarchive.com/dlmain/Datasheets-110/DSAP008954.pdf
anniel Posted - 06/18/2016 : 03:06:19
It is also used in other circuits. It is a MN12C201D and the closest to a pinout diagram I have found is this.
As for a datasheet I only found this www.datasheetarchive.com/dl/Scans-063/DSA2IH00135188.pdf
ZLM Posted - 06/17/2016 : 20:56:32
This chip seems a TV chip.
