 Add device: MX29F800C
Ziggy587 Posted - 08/13/2016 : 17:04:37
Hello,
I see similar devices but they are not working for me. Can we please add MX29F800C to the supported devices?
MX29F800CTTI
MX29F800CBTI
Data sheet: h**p://www.macronix.com/Lists/Datasheet/Attachments/3094/MX29F800C%20T-B,%205V,%208Mb,%20v1.2.pdf
Thank you!
Ziggy587 Posted - 08/14/2016 : 06:22:37
Those lines worked, thanks!
For the record, I was using the wrong base adapter. The PSOP versions of those chips would probably work as well.
ZLM Posted - 08/13/2016 : 23:41:23
Try those lines:
Name="MX29F800T*TSOP48",ID="C2D6",Class="29F800T",Category="FLASH",MFG="Macronix",Adapter=""ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Speed="3",Message="Set the adapter to 5V jumper position.";
Name="MX29F800B*TSOP48",ID="C258",Class="29F800B",Category="FLASH",MFG="Macronix",Adapter=""ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Speed="3",Message="Set the adapter to 5V jumper position.";
