 Programming EN29LV040A
zebedee2001
Posted - 11/10/2009 :  11:10:28  Show Profile
Semi-new to programming (done PICs before). I have a Willem V3.1 single sided programmer, can I use this to program a EN29LV040A? I notice that the 0.97ja lists 29F040 but not the LV. This device is a 3V device. IF I can what setting do I need & how do I connect ISCP to the V3.1?
All help appreciated. Need to reprogram my TV!
Posted - 11/17/2009 :  08:16:30  Show Profile
EN29LV040A is not supported on V3.1. The V3.1 only has 5V voltage. Unless you mode the circuit to provide 3.3V voltage.
The ICSP does not work on EN29LV040A chip.
zebedee2001
Posted - 11/24/2009 :  11:15:19  Show Profile
Ok, will have a go at modding supply
