 USB PIC Programmer for 18LF1330
Lainus
Posted - 03/05/2010 :  09:50:40  Show Profile
Hello,
I have used a 18LF1330 with ICSP.
For burn, I have tried with 18F1320, and the burn is correct, but the program doesn't run.
The program is very simple and write with CCS.
With Proteus ISIS, run correctly.
Please, can you help please?
Thank you
Lainus
Posted - 03/05/2010 :  10:46:28  Show Profile
#include <18f1330.h>
#FUSES INTRC_IO,NOWDT,NOPUT,NOMCLR,NOBROWNOUT,NOPROTECT,NODEBUG,NOFCMEN,NOIESO
#use delay(Internal=4M)
#use standard_io (a)
#use standard_io (b)
void main()
///Configuració pinout // set portc 0=sortida 1=entrada
set_tris_a(0b01111010); // set portA configuració pinout
set_tris_b(0b00001100); // set portB configuració pinout
output_high (PIN_B1);
output_high (PIN_B5);
//////////////////////////////bucle infinit...........
While(true){
output_high (PIN_A0);
delay_ms (500);
output_low (PIN_A0);
delay_ms(500);
if (input (pin_a5)){
output_high (PIN_B4);
else{
output_low (PIN_B4);
Lainus
Posted - 03/06/2010 :  10:31:16  Show Profile
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=1313
Generated in 0.3 sec. Snitz Forums 2000
