 PRG-022 with 16F648A - Not working
jkittle99
Posted - 06/07/2010 :  19:26:40  Show Profile
I've got a new enhanced jdm programmer and 16F648A chip. This thing is on drugs :) Tried every piece of software I can get my hands on, and not able to successfully write a chip. Using external 12v for programming to eliminate low voltage serial port issues. So the short is - I run an erase, and try to blank verify, and it mostly comes back not blank. I try to write something, and it comes back failing verification. Can somebody please tell me how to get this working?
jkittle99
Posted - 06/08/2010 :  06:49:20  Show Profile
I found out the chip was originally programmed HVP. If that matters.
j
Posted - 06/10/2010 :  16:06:15  Show Profile
check your configuration bit. If you want to verified it after write, then the code protect bit should be OFF.
