 GQ-4X Win10 Bacth Run (Auto)
ReneBrunier
France
Posted - 11/16/2015 :  02:46:48  Show Profile  Reply with Quote
Hi MCUmall,
I was using GQ-4X Re=1.40 (SW Re=3.36) on a W8.1 machine. Was good.
I just updated to W10 and now the batch run button is no more working.
It looks like burning is running but in reality the chip is not burned at all. Even more verification tells everything is fine but it is not (I used to select 'Verify' in the batch tool).
To get a "real" comparison, I have to open the code file again and launch a 'Verify' command. It then shows that the chip does not have the same code as the source file....
Looks like the "Auto" button is re-writing the same code as the one into the chip ????
No other way than to do the operations "manually" : clear/ check blank / Write / Verify.
Not sure if I need to update the software ??
any clue ?
thanks
René
Posted - 11/18/2015 :  08:04:58  Show Profile  Reply with Quote
Update you software to latest version.
ReneBrunier
France
Posted - 11/19/2015 :  00:57:59  Show Profile  Reply with Quote
Thanks ZLM
Downloded Re6.38 and its working again.
René
