Is there an adapter combination that allows programming TSOP48 packages of the 29F040 series? In particular, I need a solution for programming 48-pin TSOP package of AM29F016b chips. I've successfully programmed the 40-pin package of this same chip using ADP-082 and ADP-077. The difference is subtle, there's 2 extra NC pins on each of the 4 corners: hp://files.zzattack.org/img/upload/tmpB20E.png
Can I just shift the adapter on the base board and move it up 1 row? Or is there another adapter I can use?
Edit: just tried it. Shifting the top board adapter by 1 row works.
