 Cannot program SST39VF020@PLCC32
tokyoskies Posted - 07/25/2022 : 04:32:52
Hello,
thank you very much for making this cool programmer. Unfortunately,
I cannot program any SST39VF020 with PLCC32 socket. I have tried 10 different EEPROM Chips, some I bought new last week. I also tried several different settings, including custom setting
Name="SST39VF020*PLCC32R",ID="FFFF",Class="SST39LF/VF020",Category="FLASH",MFG="SST",CodeSize="262144",VCC="3.6V",RVPP="5V",WVCC="5V",Adapter="ADP-062, ADP005 PLCC32-DIP32";
I always get a either an ID error (if I use BFD6) or a writing error. For reference, I tried to erase a chip containing a firmware, and it completed successfully, but the chip was not erased. What am I doing wrong?
Ready
GQ-4x4 1.0 @ SW Re. 7.29
USB Driver Re.3.0
Software Re. 7.29
Serial #: I90927433Y
Configuration OK!
<<SST39VF020*PLCC32R>>
ID check OK
Writing... Buffer
Elapsed time: 2.92 seconds.
Device write completed OK
ID check OK
Verifying... Buffer
Device is verified
Elapsed time: 7.28 seconds.
c:\users\arvos\desktop\new folder\air_master.bin.
ID check OK
Writing... Buffer
Elapsed time: 0.34 seconds.
Write failed, Address=0x000000, Buffer=0xA0 Device=0xFF
Write failed
CSnowtail Posted - 08/25/2022 : 09:45:47
Im having the same issue. All chips show up as FFFF ID, wont erase, and wont write.
tokyoskies Posted - 07/27/2022 : 06:25:34
I tried a different chip, AMD AM29LV040B-120JC
same results, Chip ID fails with FFFF
I am starting to consider both PLCC32 to DIP32 adapters may be the issue.
