 problem GQUSBprg 3.01
ingrds Posted - 08/25/2008 : 09:17:48
i have problem with last version GQUSBprg 3.01 in my programer
the device is not supported on this programer version
you need to upgrade ther programmer o firmware
i need programmer sst25vf016b
i have revision GQ-3X Re-1.00
ZLM Posted - 08/26/2008 : 01:43:45
To do this, should download Re3.01B or later version software.
ZLM Posted - 08/25/2008 : 20:38:14
The comparison table is covered main points only.
The official supports list does not include sst25vf016b. It is only included in the GQ-4X supported list.
But the GQ-3X still be able to supports sst25vf016b. It only in just very slow mode on this chip. You can add this chip youself if you want.
For testing, try to add this line to devices.txt:
Name="SST25VF016B(Slow mode)",ID="BF41",Class="SST25VF020",CodeSize="2097152",VCC="3.6V",Category="SERIAL_EPROM",MFG="SST",Speed="1",Message="To get fast operation, please upgrade to GQ-4X";
ingrds Posted - 08/25/2008 : 19:28:05
i see
True USB willem Universal Programmer Series Comparison Table
True USB GQ-4X <-> True USB GQ-3X
but they are equal
ingrds Posted - 08/25/2008 : 19:06:09
I NEED BUY OTHER PROGRAMMER I CAN USE MY Q3X
ZLM Posted - 08/25/2008 : 13:19:17
This chip is only supported on GQ-4X programmer.
