 reading / writing ambit 256 mx25l1605 spi chip
nampilys Posted - 12/01/2008 : 09:03:00
this is an update to my previous post:
to read/ write to this chip you need:
  • GQ-4X (3x will work but takes 40mins as opposed to 4 on the 4x)
  • SOIC-20-dip adapter (8 pin does not work as the 1605 is a 300mil device and does not fit)
  • GQUSBProg v3.03 (beta version lurking in some other threads, hopefully final version will be released soon
  • found it again: http://www.mcumall.com/download/TrueUSBWillem/GQUSBPrgRe3.03Beta.zip
  • insert mx25L1605 into lowest portion of soic 20 adapter
  • insert soic adapter in lowest portion of zif socket
  • devices - serial eeprom - macronix - 25L1605A
  • click id - chip should be identified
  • read / write / erase as per normal
sadly the 3x and 4x do not support in modem spi flashing as the spi adapters for these do not support the 3.3v/5v booting trick
to prove it works: - timings done on GQ-4x reading and writing a full 2MB flash
ID check OK
Erasing...
Elapsed time: 14.65 seconds.
Erase completed.
ID check OK
Time:16:43:08
Writing...
Elapsed time: 245.66 seconds.
Time:16:47:14
Device write completedOK
ID check OK
Verifying...Code Memory
Device is verified
Elapsed time: 243.19 seconds.
ZLM Posted - 07/26/2010 : 15:51:37
If you use ADP-081 and chip you can get correct chip ID, can be erased and blank checked. Then you may try to slow down the speed. You can set to 0 or -1 to try.
jaki Posted - 07/26/2010 : 07:17:27
Hello
I have already problem with programing this chip. I use adapter ADP-081
Have check on 2 chip but noone is ok. Support have me sugest that i must check if chip are erase and blank. This is ok but i can't programing noone. Please have you sugest how to make this.
regards
nampilys Posted - 12/07/2008 : 12:44:38
the modem is the ambit 256, the sb5102 is pretty much identical being spi based (uses the spansion equiv of the macronix chip)
the current spi header either gives id 000000 with the modem unpowered of ffffff with it powered
the spi header cannot power the modem circuirty its self, ive got the reverse engineered schematics for the current programmer here somewhere, il dig them out and post them to give an idea of how it works
ZLM Posted - 12/05/2008 : 15:06:23
What is your modem model? I just got one SB5100. I need to do some testing.
nampilys Posted - 12/05/2008 : 08:00:15
to be perfectly honest i dont know the reason for part booting the cpu... the only programmer we have for flashing these chips while still in the modem only works when the cpu has been part booted
have tried the mcumall isp adapter and it only gives an id 000000 for the chip, even tried using an external ps for the 5v/3v3 to perform the trick and still nothing
ZLM Posted - 12/05/2008 : 02:05:21
The programmer is able to provide 5V voltage and then switch back to 3.3V at any time. But why it needs power up the CPU? If need to program the SPI chip, then use a test clip on the SPI chip should work.
nampilys Posted - 12/04/2008 : 04:45:43
the adapter we need is as follows:
extend the 8 pins for the soic to an 8pin soic test clip
be able to provide 5v (modem uses a max of 400ma) directly to the spi chip to bootstrap the cpu then be swichabke to 3.3v for programming without the modem booting
have done some experimenting with the current spi in circuit adapter using an external psu for the 3.3/5v but the gqprogrammers are unable to recognise the chip
ZLM Posted - 12/02/2008 : 20:22:55
Thanks for the update. The GQ-4X SPI speed can be further optimized to be faster. The GQ-3X and GQ-4X is capable to support all modem SPI flash chips. Please let me know your requirment for that and I believe we can make it. If you have any design idea you can let me know too, we can make software change to fit your adapter design. Let GQ programmer do more job on modem.
