 AT49BV320D
sylverster16v Posted - 01/01/2009 : 15:37:02
I dont know,why i have no luck with gq-4x and Tsop chips
GQ-4X Re-1.10 with and without 9v ac-adapter
Tsop48 8/16bit v2.0 adapter , J2(29F), J1(5V)
and a brand new AT49BV320D
it doesnt matter what i pick from device list:
AT49BV320 or AT49BV320T
it gives me back 0000 device id
lock-funktion says chip is not locked
un/check temp unprotect no changes
164.48 KB
135.51 KB
159.96 KB
i know you will say,check pin contact....but i cleaned the chip and checked the pin orientation more than 20 times
ZLM Posted - 01/02/2009 : 22:52:56
Found some thing wrong with the device line. It should use 16 Bit adapter. Not 8/16 bit adapter.
Not fully supported this chip. The software need to be updated to get correct ID. The adapter base board needs some changes in order to support this chip.
The chip should be removed from the supported list for now.
Try to change the device line to:
Name="At49BV320",ID="1FC8",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="5",CodeSize="4194304",Adapter="TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 28FX00 position.";
The ID is not fully work. It will read 3 bytes instead of 2 bytes. Aalso, this works on first half of size due to the A20. A20 should connect to pin 10 but it connected to pin 9 in this case.
sylverster16v Posted - 01/02/2009 : 17:22:10
no idea?
