 error 29lv160attc and 29w800dt
nicotinetar Posted - 01/12/2009 : 23:03:23
hi dear mcu electronics.
i just bought true-usb willem programmer and tsop48 16 bit adapter. I want to erase and write both of them but there are always error. I clicked temp. unlock and again fail. I use the program gq usbprog 3.0.3
(latest). And how can connected wire .(i have three. white red green.)
I read all articles and forum pages but there s error erasing and writing. What can i do about this ? Thanks...
nicotinetar Posted - 01/13/2009 : 00:23:11
Thanks again dear mcu staff.
Now i m happying to buy true-usb for fast support. Have a good working
ZLM Posted - 01/13/2009 : 00:13:10
Those two adapters are not same. 8/16 bit adapter does not means it supports both 8 bit and 16 bit programming mode. Basically it means that it is for chips have both 8 and 16 bit mode programming. The 8/16 bit adapter only programs the chip with 8 bit mode.
The 29LV160 and 29W800 has both 8 and 16 bit programming mode capability. So, they use 8/16 bit adapter.
Both adapter use same ZIF adapter top board. So, you only need a 8/16 bit base board. You can write a email to sales@mcumall.com ask for the base board availability.
nicotinetar Posted - 01/13/2009 : 00:01:29
Thanx for fast reply.
I have got a few questions.
16 bit adaptor dont support these chips , you say that. can we convert this adaptor to 8 bit ?
If ı buy 8/16 bit adaptors , will i use it to both 8 bit and 16 bit both of them (without problem)?
Can I use any willem adaptors (w-ub or eprom programmer) on this programmer? (without any problem)
And last thing , can we use his programmer with orjinal w-usb willem program (WUSBProg)?
ZLM Posted - 01/12/2009 : 23:40:20
Both chips use TSOP48 8 bit adapter. not the 16 bit adapter.
see:
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=3102
The 29W800 does not need the address wire. And the 29LV160 need connect A19 only. I assume you have GQ-3X, then connect the A19 from programmer A19 to Adapter A19 address pin. Set the voltage jumper on the adapter to 5V position.
