 sharp L.H.F.8F008SCT trouble reading and id
Shaz Posted - 02/02/2009 : 18:59:13
Using the gq-3x I have the TSOP40-DIP40 ZIF adapter connecting to the FWH/LPC+ that came with the programmer and it has 20 pin rails soldered in the correctly marked place. I'm using the sharp lhf08ch_1 device and get a device id of 89A6A6. It seems to read fine but will vary in results and when clicking verify I get errors of, address=0x00000057, device=0x96, buffer=0xFD and seem to get errors with variety too.
All pins seem to be contacting in the adapter. Any help? Thanks
Had to put periods in otherwise it would create links?
Shaz Posted - 02/04/2009 : 18:20:54
Thanks, I talked to them and we have things worked out :) Great Support
ZLM Posted - 02/03/2009 : 22:17:56
Currently the TSOP40B adapter is part of 20mm TSOP complete set. It uses TSOP48 ZIF socket board on a TSOP40B base board.
see:
www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4224
If you only need TSOP40B adapter then write to order@mcumall.com for availibility.
Shaz Posted - 02/03/2009 : 07:06:51
I made the device LHF08CH_1 and tried it out, but if you have one that is sure fire to work that would be good. Also the adapter is not soldered onto the FWH/LPC it connects to some pin headers. Where can I find the TSOP40B adapter and I guess the 48pin adapter that goes with it?
ZLM Posted - 02/02/2009 : 23:17:56
Did you mean you soldered the TSOP40-DIP40 on the FWH/LPC+ adapter?
What device you selected from the software?
But according to the sharp LHF08CH_1 datasheet, it is not he FWH/LPC chip. It is flash chip and it should use TSOP40B adapter. Solder the TSOP40-DIP40 adapter on FWH/LPC adapter will not work.
