 Question About Supported Eprom Chip
sefi Posted - 02/09/2009 : 12:21:17
Hi, id like to know if the HN462532 is Supported by the True USB Willem Programmer? in the Supported Device List(Re. 3.03) the HN462716 apprears on the list and from my comparison of the data sheets it looks alike but id like to hear a more professional opinion.
here are the data sheets
HN462716 www.datasheetcatalog.org/datasheets/320/500344_DS.pdf
HN462532 www.jrok.com/datasheet/HN2532.pdf
thanks
ZLM Posted - 02/09/2009 : 20:58:21
The HN462716 will work since it is compatible with standard 2716.
The HN462532 datasheet says it is fully compatible to TMS2532. So, it should work when you select the TMS2532.
Try it see if it works. If works then let us know we can add it in the supported list. We do not have this chip for testing.
