 line to add for M29W400BT support
Bad_Ad84 Posted - 03/28/2009 : 12:07:18
Name="M29W400BT",ID="20EE",Class="29LV400B",Category="FLASH",MFG="ST",Adapter="TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
need to have temp unprotect enabled, but works fine.
ZLM Posted - 03/28/2009 : 20:29:59
Thanks. It will be added in next software release.
It seems that the chip is locked. So, you have to enable the temporary unprotect feature.
