 trouble writing 93c86 with gq-3x re-1.40
k0mpresd Posted - 05/04/2009 : 17:15:42
reads ok but just writes a bunch of ff's and a few random characters. tried 2 different adapters, same problem. also tried each 93c86 eeprom listed in software. none write ok. having to use para willem to write chip.
solution?
edit: used -2 speed and device programmed ok.
k0mpresd Posted - 05/04/2009 : 18:58:55
thanks for the reply. device has been programming ok each time at 0 speed and by selecting at93c86 device. cheers.
ZLM Posted - 05/04/2009 : 18:19:29
It seems the chip is sensitive to the speed.
Use "-2" speed then if it works on this speed.
