 15 group per line
yelenavik Posted - 05/10/2009 : 18:42:36
I installed programm GQ-4 in laptop Dell D600 with XP pro and get 15 group per line, same in Toshiba laptop with XP home 16 group-is correct.I can't change to 16.Could you help to change?Thank's.
dupontg Posted - 05/20/2009 : 14:14:23
Thank you very much it's OK for me too!
yelenavik Posted - 05/13/2009 : 08:44:52
ZLM,great job.Now working excelent.16 per line.All right.Thank You.ver 4.02 beta 1
yelenavik Posted - 05/13/2009 : 08:43:06
ZLM Posted - 05/13/2009 : 06:58:33
Can you download the patch again?
http://www.mcumall.com/download/TrueUSBWillem/USBPrg4.02Beta1Patch.zip
yelenavik Posted - 05/12/2009 : 09:32:39
ZLM,ver,4.02beta 1 with patch ,give me 15 .Only with 4.beta5 give me 16 with message board on the middle,I posted before.
ZLM Posted - 05/12/2009 : 06:34:30
The patch does not work standalong, it only works with other files under "C:\ProgrammerFiles\GQ USB Programmer" directory with all other files together. So, you need to overwrite the Re 4.01 USBPrg.exe in that directory with this file.
yelenavik Posted - 05/12/2009 : 00:54:11
Hi ,ZLM.Patch not working(encountered problem).I found,that problem 15 in buffer in ver,4.01 for older laptop.Now working 16 in buffer with ver.4.00 beta5, but have same problem: message board(log)located on the middle and cover device location.
ZLM Posted - 05/11/2009 : 15:20:13
Try the testing patch:
unzip and copy to the software directory. Overwire the old version USBPrg.exe file.
Let me know if it works.
yelenavik Posted - 05/11/2009 : 11:53:15
laptop with res 1400x1080,but I tried change to 1024x768 dont help
122.31 KB
ZLM Posted - 05/10/2009 : 22:02:41
can you post a screen copy?
if the image too big, the upper half will be fine.
thanks.
Generated in 0.36 sec. Snitz Forums 2000
