 16F88 Configuration flags w GQ-4X
busterk Posted - 06/20/2009 : 10:35:13
- I have problems with the configuration flags of the pic (0x2007)
- I'm setting the flags manually which results in the word 0x3F18
- When I'm programming the pic the CFG gets written as 0x3FFF all "1".
-Why could that be ?
- When my program was smaller it worked.
busterk Posted - 06/22/2009 : 11:20:17
The USBPrg is always use .bin file as default. We can added a setting option on this point.
I would like that very much as i always use *.hex files myself
Thanks DD
ZLM Posted - 06/21/2009 : 16:53:56
busterk Posted - 06/21/2009 : 12:54:12
Can you try it again on smaller program again?
I just want to confirm the problem can be reproduced.
I found a workaround , i just erase the code and write new code
now the CFG is unchanged and i can use the pic again.
But using the read /wrte CFG dint work as i hoped it would.
Can i Change the default load file in USB Prog
to *.hex and not *.bin.?
ZLM Posted - 06/20/2009 : 23:21:57
