 Support for SST 49LF160C (GQ-4X)
Bruce Posted - 07/06/2009 : 05:48:59
I will need to program this chip soon, using the GQ-4X. It does not appears on the list.
It is supposed to work the same as SST 49LF004B series, only it has 16mbit... Would it work, or should i need to wait for a new version of the software ?
ZLM Posted - 07/06/2009 : 19:57:52
Try this:
Name="SST49LF160C",ID="BF4C",Class="INTEL82802AB",Category="FLASH",MFG="SST",CodeSize="2097152",Adapter="ADP-030, ADP-057 FWH/LPC+";
Bad_Ad84 Posted - 07/06/2009 : 11:44:07
you can add a new device in the devices.txt file, if its the same as the 49LF004B, you can copy that line and rename it. you would just need to change the size and ID code before saving it
