 HN27c4000 error in devices.txt
billd420 Posted - 07/15/2009 : 19:32:10
Hello-
I couldn't for the life of me get HN27c4000 eproms to burn with my GQ3x programmer. I was using software 4.1, upgraded to 4.2, then downgraded to 3.0. All versions instantly failed when programming this device.
I opened up the devices.txt from version 3.0, and noticed that HN27c4000 is set to RVpp="5v". After looking at the datasheet, these chips need 12v to program. I added the following paramaters and the device now burns perfectly, every time:
Name="HN27C4000",ID="XXXX",Class="27C800",Category="EPROM",MFG="HITACHI",CodeSize="524288",WVCC="6.5V",WVPP="12V",Adapter="16 BIT EPROM Adapter DIP42",RVpp="5V",Message="Put chip in 42 pin socket and bottom aligned with the socket.";//by EZo - fixed by billd420
Hope that helps someone else!
-Bill
ZLM Posted - 07/16/2009 : 21:46:12
Thank you for your information.
