 MX29LV160CB hanging when starting programming?
Bad_Ad84 Posted - 08/18/2009 : 15:56:51
recently when i start programming these chips, the writing box comes up, but i get no percentage and no error, it just hangs there.
if i move jumper down to 3.3v i get an error.
any ideas?
dont think is the adapter as ive tried ST chips i have.
Bad_Ad84 Posted - 09/13/2009 : 15:29:45
well its working ok now with new version
ZLM Posted - 09/12/2009 : 12:57:14
No. Nothing changed on this chip.
Bad_Ad84 Posted - 09/12/2009 : 11:04:00
just updated to the latest version and its working ok now?
Bad_Ad84 Posted - 09/12/2009 : 10:57:34
i have several trays of them, i will send you some
ZLM Posted - 09/10/2009 : 23:05:59
If that is the case, then the chip may have programming compatibility issue I think. They have different production batch. IF you have more chips, you can send a sample chip to support@mcumall.com for fine tuning the algorithm.
Bad_Ad84 Posted - 09/10/2009 : 17:55:11
yes the MX29LV160CB works on 16bit but not on 8/16.
however it used to and i always used the 8/16 in the past...
ZLM Posted - 09/10/2009 : 17:00:18
Do you means the MX29LV160CB works on 16 bit adapter but does not work on 8/16 bit adapter?
The 16 bit adapter and 8/16 bit adapter use different programming algorithm. I think this is compatibility issues. The chip stops response to the programmer, but the programmer waiting for the response.
Bad_Ad84 Posted - 09/10/2009 : 16:31:04
any ideas? still not working..
Bad_Ad84 Posted - 08/19/2009 : 14:11:47
also the MX29LV160BB works fine in the 8/16.....
Bad_Ad84 Posted - 08/19/2009 : 13:57:12
seems its the adapter? it works in 16bit adapter but not in 8/16.
any idea why the st chips work in the 8/16 adapter but the mx's dont?
Bad_Ad84 Posted - 08/18/2009 : 16:05:03
just read some of the chips, seems its programmed maybe the first 0.2% of the chip
