T O P I C R E V I E W |
P-E |
Posted - 11/11/2009 : 13:37:55 Hello i'm looking for an adapter to read/write this chip 29F016-90PFTR (reverse pinout)
does this one is ok ? http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=3102
thanks a lot Pierre |
10 L A T E S T R E P L I E S (Newest First) |
osvaldo |
Posted - 11/18/2009 : 14:04:51 The idea is this. The adapter is soldered to the memory backwards to have a good connection to connect the other adapter cable with two throws to make the connection and to program
This is temporary when you can armo an adapter as the ADP-003 TSOP48 8 / 16 bit to program without such complications |
osvaldo |
Posted - 11/18/2009 : 05:03:39
45.04 KB
30.86 KB
89.04 KB |
osvaldo |
Posted - 11/18/2009 : 05:01:50 You go up this info. If you have served is a circuit of an adapter that I used once to a case like yours
21.66 KB |
osvaldo |
Posted - 11/17/2009 : 10:45:39 A consultation can tell me where this device is affixed to see if there is another way to extract data or upload data without removing the memory where it is placed if possible send you the information to my mail or go up in the forum from now thanks If the question is if I can design an adapter that memory if I can but first and foremost would have to consult with the company or MRZ mcu who is the representative of the forum to see that view to have more help ------------------------- Una consulta me pueden decir donde esta colocado es dispositivo a ver si hay alguna otra forma de extraer los datos o de cargarle los datos sin sacar la memoria donde esta colocada si es posible mandaren la información a ,mi correo o suben en el forum desde ya gracias Si la pregunta es si yo puedo diseñar un adaptador para esa memoria si puedo pero ante todo tendría que consultar con la empresa mcu o con zlm que es el representante del forum a ver que opina para tener mas ayuda
Bad_Ad84 |
Posted - 11/16/2009 : 15:14:35 you could make an adapter that sits between the tsop48 socket and the bottom part of the adapter that will reverse the pinouts. |
osvaldo |
Posted - 11/15/2009 : 13:53:35 Friend what I'm going to explain what does one see one with a DVD player that will damage the finwares of that memory and this is what ice
1 you have to bend the pins of the memory to the other side that what, aces in a flat and then you put it into the adapter and should work
37.97 KB |
P-E |
Posted - 11/15/2009 : 02:40:00 Hi Osvaldo
thanks for the help it's the pinout of the below chip on your picture if you have an hint to program it ,i'll be glad to take it ^^
best regards |
osvaldo |
Posted - 11/12/2009 : 12:57:02 I put a photo of the 29F016 you tell me what you got the one above you or below have an idea to solve your problem
34.58 KB |
P-E |
Posted - 11/12/2009 : 10:21:08 ok thanks for the info the adapter is on the way or no way it'll be done ? |
ZLM |
Posted - 11/12/2009 : 01:14:12 if your chip is TSOP48 reversed,pinout then currently does not support. No adapter for it. |
