 problem writing AM29F400BT
engert81@gmail.com Posted - 12/14/2009 : 12:54:38
while i am writing the flash an error occured always on 6%
Write failed, Address=0x008000, Buffer=0x54 Device=0x87
what can i do???any help
ZLM Posted - 12/15/2009 : 08:03:21
Did you erase the chip and pass the blank check?
Did you try to turn on the Temp. Unprotect function?
Can you confirm you have good pin contact with the programmer ZIF socket?
