 any chance for w29c040 (ID=DA46) for the GQ-4x?
plgDavid Posted - 12/22/2009 : 12:11:10
Hi
Since you already support W29c020, how hard would it be for that one?
Name="W29C020",ID="DA45",Class="SST29EE020",Category="FLASH",MFG="Winbond";//edited by EZo
seems the app doesnt have a SST29EE040 class for me to add
Bad_Ad84 Posted - 01/21/2010 : 09:28:09
you can use version 5 with your firmware....
you only need the updated firmware for a couple of chips, the software will still run fine
plgDavid Posted - 01/21/2010 : 05:56:37
Hi
ZLM: Doh, seems like its been added after v4.01 (which is what im still using since I only have CQ-4X firmare:re-1.20).
Ive just compared both device.txt files, and indeed thre is now a W29C040.
osvaldo: thanks for the help.
osvaldo Posted - 01/20/2010 : 12:22:22
Hola plgDavid veo que todavía no solucionaste tu problema, escapas q esto ya lo hiciste probaste con otro chips igual por las dudas, cundo pones a leer el chips lee bien o te genera un error
ZLM Posted - 01/19/2010 : 15:19:07
I found the w29c040 chip in the supported list:
Name="W29C040",ID="DA46",Class="AT29C040A",Category="FLASH",MFG="Winbond";
plgDavid Posted - 01/19/2010 : 08:01:40
Bump, any word, anything from MCU Mall? Can be hard to answer "Yes its in the Todo list" or "No it cant be done with this hardware" (doubtfull)
plgDavid Posted - 12/23/2009 : 09:06:34
Hi
Ive already tried that, but the SST29EE040 class doesn't exist internally to USBPrg.exe (and theres no datasheet anywhere, i doubt it even exists)
Apparently the W29C040 class exist in the old willem "EPROM45" app
osvaldo Posted - 12/22/2009 : 18:39:07
See if you can solve this problem
Name="SST29EE040",ID="BF10",Class="SST29EE040",Category="FLASH",MFG="SST";
Name = "W29C040", id = "DA46", class = "SST29EE040", Categoría = "Flash", MFG = "Winbond"; / / editado por Ezo
