 5.0 Bugs
Bad_Ad84 Posted - 12/28/2009 : 12:25:55
in file -> open you have 2 .bin filters, the first one doesnt always work and isnt required. "bin files (*.bin)" and "Binary Files (*.bin)
when you search in devices, then change your mind and delete it, your new search doesnt show up, you have to close the devices page and reopen it for your search to work again.
Necrosaro420 Posted - 02/20/2010 : 21:09:11
Not sure if its a bug, but none of my 801's will burn with the 5.0 software, after it burns, it fails on verify, and then does a blank check to 100%
Bad_Ad84 Posted - 02/20/2010 : 05:50:14
That is not a bug.
That is last file type you selected. It will change to .hex if you select the hex file type.
theres 2 filetypes, the first .bin is wrong....
*.*.bin wont match files correctly...
"bin files (*.*.bin)" is wrong and needs to be removed
Binary Files (*.bin) is correct
dont need both and first one is wrong anyway
ZLM Posted - 02/19/2010 : 11:27:03
That is not a bug.
Bad_Ad84 Posted - 02/19/2010 : 01:12:05
search seems to be working now, not sure if you changed anything but this is a different machine to the one i had problems with.
window size is now fixed.
there is still 2 .bin filters in the open dialog, the top one needs removing.
147.89 KB
Bad_Ad84 Posted - 02/19/2010 : 01:02:43
which problem? theres 3 listed in this thread?
ZLM Posted - 02/18/2010 : 11:34:52
Basically I could not reproduce the problem.
Try to download the 5.01 Beta again and see if anything improved.
Bad_Ad84 Posted - 02/18/2010 : 02:35:39
ZLM, just making sure you have seen this as both arent fixed in 5.01beta
Bad_Ad84 Posted - 01/13/2010 : 10:06:42
default start window is slightly too small (this is purely cosmetic, but annoying)
picture below of what it is and what it should be like:
106.98 KB
89.68 KB
ZLM Posted - 12/28/2009 : 23:02:16
thanks. Will be fixed.
