T O P I C R E V I E W |
pentu |
Posted - 01/03/2010 : 06:16:05 Hello, I am novice in bios programming, in fact GQ-4X is my first programmer. i dont know the anything about bios programming, i had a dead hp laptop motherboard because bios is corrupted (i cross checked with working bios), the chip is SST49LF008A, i used firmware hub to insert the chip and read but the device id it is showing wrong, if i continue to read, erase, blank check it says ok but when i want to write with .bin file it says 'address fail 0x000000, offset, pls help me
Thanks |
ZLM |
Posted - 01/06/2010 : 14:06:12 It seems there are bad contacting somewhere in between the adapter, chip and programmer.
Please check the pin contacting again. Also, the chip pin 1 orientation
