T O P I C R E V I E W |
aramor |
Posted - 01/28/2010 : 12:10:45 Hi! Are there any solution to write SPANSION S29GL032N90? I didnt found this type in the device list. Tryed it with some other same type, but the writing process stopping at 25%. The read and erase working well. Help me please! |
7 L A T E S T R E P L I E S (Newest First) |
aramor |
Posted - 01/31/2010 : 01:45:21 I got 017E device ID, manufacture AMD, type unknown device. Selected S29AL032D..-03 device from the list, but I think it also works with 29LV320B or T. The chip version is S29GL032N...-03. |
ZLM |
Posted - 01/30/2010 : 22:49:05 Which device you used from software? What is device ID you got? |
aramor |
Posted - 01/29/2010 : 12:30:54 Hi! I solved the problem, just removed the jumper J3 and everything working well. Sorry its my mistake. Thanks for helping, the A20 problem sugggest the solution :) |
aramor |
Posted - 01/29/2010 : 10:48:31 ADP-003/3102 TSOP48 8/16 bit adapter V2.0 (J3 in A19-A20 position, J2 in 29F, J1 in 5V). |
ZLM |
Posted - 01/29/2010 : 10:13:14 What adapter you used? It seems A20 address line not connected. |
aramor |
Posted - 01/28/2010 : 23:10:47 The program doesnt answer at 25%, I unplug the writer, then it say "Device write cancelled, Address=0x1000D0". Always at this address. I tried it with 2 new IC's. Maybe adapter or writer problem?
ZLM |
Posted - 01/28/2010 : 19:26:14 what is the stopping address? does it stop at exact same address?
