 GQ-4X BIOS CHIP laptop computer! SSTVF128
ABDOU13 Posted - 03/20/2010 : 06:34:48
hi I want full support for next bullet :SST25VF064 ,SST25VF128 ,SST26VF064
NOT FINDING OF FACT SHEET PDF ; ME I'M ON ITS BASE :I found some time to check your chip ID list against my chip ID database
and I have a few questions:
The following definition conflicts with the definition in my database
for SST25VF032B.
SST25VF032 0x2542
Maybe the SST25VF032 and the SST25VF032B have different IDs. Do you have
a datasheet for the SST25VF032
Do you know where I can get data sheets for the following chips? Google
turns up nothing.
SST25VF064 0x2543
SST25VF128 0x2544
SST26VF064 0x2603
Basic spiflash SA SHOULD GIVE HER? Name="SST25VF128(Slow mode)",ID="BF2544",Class="SST25VF040B",CodeSize="16777216",VCC="3.6V",Category="SERIAL_EPROM",MFG="SST",Speed="5",Adapter="SOIC8-DIP or ADP-081 adapter",Message="To get fast operation, please upgrade to GQ-4X
Name="SST25VF064(Slow mode)",ID="BF2543",Class="SST25VF040B",CodeSize="8388608",VCC="3.6V",Category="SERIAL_EPROM",MFG="SST",Speed="5",Adapter="SOIC8-DIP or ADP-081 adapter",Message="To get fast operation, please upgrade to GQ-4X";
Name="SST26VF064(Slow mode)",ID="BF2603",Class="SST25VF040B",CodeSize="8388608",VCC="3.6V",Category="SERIAL_EPROM",MFG="SST",Speed="5",Adapter="SOIC8-DIP or ADP-081 adapter",Message="To get fast operation, please upgrade to GQ-4X"; CAN YOU TELL ME IF ITS LINES ARE CORRECT PLEASE THANKS
Generated in 0.53 sec. Snitz Forums 2000
