 need to get 5.0
kyawgyi1968 Posted - 06/12/2010 : 01:26:42
Hi!!
I need help to get programmer 5.0 version. Does anybody still have 5.0. If you have it please share me. The reason i need is, I uninstalled the version 5.0 to renew with 5.02. After I uninstalled the 5.0, i can't install 5.02. It says another version is already installed. and I can't find it in the PC.I tried so many ways to do it but it's doesn't work. So I will just install back the 5.0. There is no 5.0 on the web.
This is my mail address. kyawgyi1968@gmail.com.
thanks in advance!!!
kyaw
kyawgyi1968 Posted - 06/14/2010 : 20:58:20
Here is the 5.0:
http://www.mcumall.com/download/TrueUSBWillem/GQUSBPrgRe5.0.exe
thanks million. i'll tryand let you know
kyaw
ZLM Posted - 06/14/2010 : 13:33:12
Here is the 5.0:
kyawgyi1968 Posted - 06/14/2010 : 02:52:24
Originally posted by osvaldo
fijate en el c si no tenes una carpeta con este nombbre y borrala GQ USB Programmer por que cuando desintalas el programa esta carpeta queda
Thanks Bro!!
this is my e mail. kyawgyi1968@gmail.com. Please send me the version 5.0. thx!!!!
ZLM Posted - 06/13/2010 : 21:55:02
Try 5.03Beta, it should be better than 5.0 :
http://www.mcumall.com/download/TrueUSBWillem/GQUSBPrgRe5.03Beta.exe
osvaldo Posted - 06/13/2010 : 19:49:19
kyawgyi1968 Posted - 06/13/2010 : 19:49:06
sorry!!! i don't understand that!!!
osvaldo Posted - 06/13/2010 : 19:46:39
pasame tu correo electronico y te mando el programa
kyawgyi1968 Posted - 06/13/2010 : 17:31:25
thanks,
osvaldo,
I know all the step and did it well. For some reason version 5.02 can't install on my lap top. I use add/ remove program and already uninstalled it. Already cleaned the regisrty files. Stiil can't install. That's why i want ti try back to install 5.0. But i don't have it now. Can somebody send 5.0 pleaseeeeeeeeeee!!!!!
osvaldo Posted - 06/12/2010 : 10:28:12
---------------How to uninstall a program---------------------
If for any reason, ever need to uninstall a program Solete Software, follow these steps:
1--Open the "Control Panel" in Windows.
2--Double click on Add / Remove Programs "(or similar, depending on your version of Windows).
3--Locate in the list the name of the program you want uninstalled. Select your mouse and click on Add / Remove "(or similar, depending on your version of Windows).
4--Follow the uninstall program to appear on the screen.
5--The uninstaller will not delete your data files or directories were not created by the installation program (for example, if AquaSpelling uninstalling, the uninstaller will not delete the list of words or sounds you record, etc.). . If you want to delete those files will have to do it manually.
6--If you later decide to reinstall the program, follow the instructions in our guide
----------------How to install a program--------------------------
The file that you downloaded from our website is a self-installing program. This program contains, in compressed form, all the files needed to install the game or the tool (application, in general terms) you want installed on your computer.
To install the application onto your computer must run the self-installing. To do this, follow these steps:
1--Open the directory where you saved the file you downloaded from the internet and locate the file you want to run (eg aquaspellingsetup.exe).
2--Double click the file. The self-installing program will be executed.
3--The self-installing program will start copying and expand a number of files. These files are temporary and are deleted once the installation is complete. The files are copied to a subdirectory of "Windows / Temp."
4--After the removal of all files necessary for installation, start the self-installing program setup itself. Follow the setup instructions displayed on the screen.
5--Once installation is complete, self-installing program will delete all temporary files created during the installation process in the temporary directory in step 3. Had any problems during the process (or you cancel before the end), you may not delete any temporary files. If you want to recover the disk space you will need to manually delete them.
6--Keep a copy of the file downloaded from the Internet, in case you need to repeat the installation in future. If you give this case the downloaded file will be the only file you need to repeat the installation.
7--If you have any problems during installation (for example, lack of disk space, etc.) Try to solve it and, once resolved, repeat from step 1. It is possible that in this case, receive a message that the file you are trying to copy already exists. Answer these questions as it deems appropriate.
8--If for any reason, you need to uninstall the program, follow the instructions
