 Blank Check hangs forever
hindered Posted - 06/19/2010 : 17:33:46
Hi all,
I've searched the forums and have not found an answer for this situation, my apologies if I missed it. I just bought a GQ-4x and I have the most up-to-date version of the software and driver.
I am trying to salvage some chips from nonworking arcade boards. I have a handful of HN462532G chips that cause the software to hang when I do a blank check on them. The software just sits there on an empty progress bar until I click Cancel. If I then attempt to do any other action, (Read, etc) the software attempts to do a blank check again.
The reader has the VCC light on and it does not turn off until I remove the device from the system.
What does this mean?
hindered Posted - 06/21/2010 : 13:16:17
Thank you for the reply. I have several HN462532G chips that work properly as (I believe, from memory here) TSM2532. It is just two chips that choose to hang on blank check.
Are these two chips bad?
ZLM Posted - 06/20/2010 : 23:24:53
The chip is not in the supported list.
You may try on 2532 but it is not guaranteed.
