 GQ-4x Problem writing to 28f001-bxt
Imanu Posted - 07/01/2010 : 04:31:18
Hello I have problems writing to p28f001-bx-t120.
To read I use a resistor between pin 1 and 30. But I can not write to the memorie.
Programmer GQ-4x
Software Re. 5.03 Beta
It does seem to write but it does not pass the verificacion and actually nothing is writen to the memorie.
Thanks for help
Imanu Posted - 07/02/2010 : 01:33:02
Works!!!!!! thanks
What is the url of hte support root to look for more help on other stuff?
tks
Imanu Posted - 07/01/2010 : 13:02:15
Tks, I will try isolating pin 30 and use the resistor jumper.
ZLM Posted - 07/01/2010 : 09:17:23
Did you see :
http://www.mcumall.com/support/28F001_PLCC32_GQ-3X.jpg
http://www.mcumall.com/support/28F001_GQ-3X.jpg
The GQ-4X will be similar.
Imanu Posted - 07/01/2010 : 04:38:01
I also have problems erasing the 28f001. It sends a message that says function not supported and I need to disconnect the programmer and reconnect to make it work again.
Thanks for help
Generated in 0.26 sec. Snitz Forums 2000
