 Adapter for SPI 95080
speedcar Posted - 07/05/2010 : 10:01:30
How can I connect a SPI 95080 with GQ-4X without adapter? I have a 3M SOIC-8 how can connect with the ZIF socket? anybody knows?
ZLM Posted - 07/08/2010 : 11:27:33
1. check your connection.
2. Use balank check to confirm if the reading is blank. If it is blank, then the chip may be a blank chip.
speedcar Posted - 07/08/2010 : 09:22:45
When I connect the chip in that form, the programmer only read in blank!
ZLM Posted - 07/07/2010 : 16:41:55
The chip is at the lower part of ZIF, so the VSS pin is pin20 of the programmer ZIF. That is the connection.
speedcar Posted - 07/07/2010 : 15:45:52
Thanks, I need to know how the connections are supposed to be in the ZIF connector so I can put the wires in the SOIC connector
ZLM Posted - 07/06/2010 : 23:36:02
4.52 KB
speedcar Posted - 07/06/2010 : 15:47:21
Thanks for your help, do you have the ZIF pin-out for the SPI EEPROM 95xxx and 35xxx,please?
Thanks a lot.
ZLM Posted - 07/06/2010 : 10:52:01
Use TOOL-012 TOOL-012A TestClip as a SOIC8 adapter
www.youtube.com/watch?v=nN5jhv-P4Fk
