 I Cannot Read Chip 93c86
windoww Posted - 07/24/2010 : 09:51:10
I Have 2 device
1.GQ-4X
2.Chinese EEprom Programer
I have Ware Clip To Read ,When I Try To Read With GQ-4X Not File Reded
All Value FFFFFFFFFFFFFFFFFFFFFFFFFFFF
Same Connection when I Read With Chinese Device Value is Correct Reading
I dont Know Whats Going On
windoww Posted - 07/28/2010 : 23:22:04
Dear sir
I have 3 device including u
When i read with your device not done
same way when i try with other 2 device work very good
tell me one things there is power supply ,when i am going to read ic 93c86 need power supply ?
my other 2 device no need power supply
tell me how to upgrade the device
ZLM Posted - 07/26/2010 : 16:00:31
Check chip ID, you should get correct ID before read the chip. Otherwise check the pin connection, contacting.
What is your chip manufacturer ?
How do you know you read from another programmer are correct?
