| T O P I C R E V I E W |
| max.augello |
Posted - 12/23/2010 : 07:03:22 I had to program a bios chip:
Winbond W39080FAP (1Mb) flash, took just seconds to clear the contents and over 25 minutes to program it fully.... using the lpc circuit of a motherboard this will take no more than 30 sec/1 minute.... what i'm doing wrong?
my pc is a QuadCore 9300 intel with 4gigs of ram and a P5WDH Deluxe (all intel hardware) in it with windows 7 ultimate 64 bits.
program installed correctly (in x86 mode) and the driver is the 2.0.1, latest version.
| 6 L A T E S T R E P L I E S (Newest First) |
| ZLM |
Posted - 01/02/2011 : 15:16:07 It seems your programmer is fine. The software needs to be optimized.
<SST49LF004> ID check failed.("FFFF") Please check device type, chip's orientation and pin contact. Some OEM chips may have compatible chip ID Continue? No ID check skipped Reading... Code Elapsed time: 43.33 seconds. Read completed. ID check skipped Writing... Code Elapsed time: 774.78 seconds. Device write completed OK ID check skipped Verifying... Code Device is verified Elapsed time: 48.71 seconds. |
| ZLM |
Posted - 01/02/2011 : 10:38:08 I will try on my GQ-4X and let you know then. |
| max.augello |
Posted - 01/02/2011 : 03:00:55 it is already on +2. |
| ZLM |
Posted - 12/31/2010 : 09:13:08 Did you changed the speed in software? put it on +2 speed and see if it makes different. |
| max.augello |
Posted - 12/31/2010 : 01:15:16 tried with another chip... same thing....
takes ages to program...
the programmer is defective?
Ready H/W Re: GQ-4X Re-1.40 USB Driver Re.2.0 Software Re. 6.00 Checking new software on server... DEVICE Device not found! Load Contacting software server failed <<SST49LF004A*PLCC32>> ID check OK Reading... Code Elapsed time: 43.39 seconds. Read completed. Controllo ID: OK Scrittura... Memoria Codice Tempo trascorso: 902.39 Secondi. Scrittura dispositivo COMPLETATA OK Controllo ID: OK Verifica... Memoria Codice Il dispositivo e' VERIFICATO Tempo trascorso: 47.95 Secondi. |
| ZLM |
Posted - 12/24/2010 : 08:55:28 Your time seems longer than normal. It may be related to chip comaptibility. Try another chip, with different version or date, that may make different.
But the programmer and the software should be good since it can program the chip correctly. |
