 mx29lv800cttc-70 with gq-4x
sylverster16v Posted - 01/12/2011 : 05:17:58
iam trying to erase the chip and everytime blankcheck stopps with 75% !
id check:ok
now i have the solution:
Name="MX29LV800T",ID="C2DA",Class="29LV800T",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="5V",Message="Set the adapter to 3V jumper position.";
speed:0
temp unprotect: aktivated
sylverster16v Posted - 01/15/2011 : 05:17:27
solution is above
ZLM Posted - 01/12/2011 : 14:16:33
Can you get correct ID from the chip?
