| T O P I C R E V I E W |
| acpr483 |
Posted - 09/22/2006 : 09:52:56 I just receive new programmer. It looks Great. What driver is required by OS (XP) Why was driver not included? I follow instructions to install Software first, then connect programmer. Software doesn't read the switch configuration, I select new device and software tell me that Switch needs changed but not show me the switch configuration??? I try with either USB power only and with USB and external Power Supply? Programmer: RE GQ-2x RE 1.00 Software Release is RE 1.04 downloaded from MCU Mall. What is U2 & U10 ? How do I resolve problems?
Thank you
Scott
| 3 L A T E S T R E P L I E S (Newest First) |
| ZLM |
Posted - 09/25/2006 : 15:43:36 The DIP setting is not a problem. The software will not read the DIP switch. Each chip has different DIP switch setting and user need set the DIP setting. The message is only a reminder. You can ignor it if the DIP switch already been set. The DIP setting is showing in the software.
See example DIP setting in the software:
 8.57 KB
No external Pwer Supply is needed. Unless you are using a unpowered USB hub.
U2 & U10 part number are the chip not been published yet. |
| acpr483 |
Posted - 09/24/2006 : 15:26:46 I followed instructions.
I guess I will send it back. I see no responses to my other questions either.
| ZLM |
Posted - 09/24/2006 : 09:30:50 Once you installed the software, the USB driver is installed too. No separated USB driver installation required if install the software before connect the programmer. |
