 Programming 27C400 Eproms problem :-(
voxel Posted - 10/09/2006 : 10:00:59
Hi
I've just bought the true usb programmer and the 16Bit Eprom adaptator with zif socket and I've some problems with it
- I don't find the 27C400 in the device list although it IS in the "supported device list"???
- no doc for the adaptator, I assume the correct orientation for it is the same direction as the onboard zif socket? is there another connection to do to the programmer?
- the software (v1.06) have a problem of window size (I've read the precedent answer to this,but this is different) as the right border overlap some of the buttons (as said in another post it can't be enlarged)(see pic)...
- is there a difference between that adaptator (mine)
31.08 KB
and this one
59.65 KB
I'll appreciate your help
Amigalement,
Jean-François, Amiga nuts since 1985 :-)
mcumall Posted - 10/09/2006 : 13:29:20
ADP-024 supports 27C322, 27C400,27C800,27C160 as well as ADP-011 supported devices.
mcumall Posted - 10/09/2006 : 11:17:28
Please write email to support@mcumall.com for more assistance.
voxel Posted - 10/09/2006 : 10:19:16
Well How can I help you ? sending a chip?
I see now I bought the wrong adaptator, but when I bought it on ebay with the programmer it was the only 16bit model to be availlable... what can we do?
Amigalement,
mcumall Posted - 10/09/2006 : 10:14:09
The 27C400 need 42pin DIP 16 bit adapter.
See:
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=3169
Currently the 27C400 is not in the supported list since we do not have chip for testing. If you would like to help us testing this chip, the we can add this chip in the supported list for you.
The software will be updated regularly. The size issue will be fixed in the future software release. Thank you for your reporting.
Generated in 3.21 sec. Snitz Forums 2000
