 Adding new device
nossi Posted - 04/07/2011 : 04:26:29
It seems to be impossible for me, to add a new device to the GQ-3X. The problem is, that I need to tell the programmer, that the CE-Input for the device is active low and needs a pulse for every adress selection to read out the data. Is it possible to do add this to the device list?
Thanksfor help
nossi
nossi Posted - 04/07/2011 : 23:56:38
....I thought this way - but now I'm shure - thanks for the answer. I just have to work it out with a "little" hardware....
nossi
ZLM Posted - 04/07/2011 : 16:18:01
The adding new device is not working that way.
If you need need a special algorithm, then the software need to be modified.
