| T O P I C R E V I E W |
| carre35 |
Posted - 04/19/2011 : 06:01:30 Hi, I just received my adapter ADP-030 and I have a w39v040bpz w39v040apz and I can not read the ID, you must set some jumper I looked at the contacts seem fine any ideas, translated with google
Greetings |
| 3 L A T E S T R E P L I E S (Newest First) |
| ZLM |
Posted - 04/22/2011 : 05:09:51 if you can confirm the chip is good, then you may need get second adapter to try. |
| carre35 |
Posted - 04/19/2011 : 09:24:25 1-I try whith 2 chip 2-pin orientation is correct 3-adapter problem i think maybe 4-programmer problem i try other chip whithout adapter y all good 5-the tipe chip is the same that list i filing the pins what i cant do |
| ZLM |
Posted - 04/19/2011 : 08:06:45 The jumper should set on TrueUSB side. Also, try V1/V2 jumper to see if it makes different.
It could be one of the followings : 1. bad chip. 2. wrong pin 1 orientation 3. adapter problem. 4. programmer problem. 5. incorrect chip type selectd from software. .... |
