 pm25LD020
starling Posted - 08/10/2011 : 12:12:28
Is there any chance this chip can be added via config?
Dmitriy Posted - 09/12/2014 : 22:12:49
Hello. Why you not added this chips in official devices.txt ?
This line for my PM25LD010
Name="PM25LD010",ID="7F9D21",Class="W25X10",Category="FLASH",MFG="PMC",Vcc="3.6V",CodeSize="131072",Adapter="SOIC8-DIP8, ADP-004";
ZLM Posted - 12/11/2013 : 00:43:43
Then use this one:
Name="PM25LD010",ID="7F9D10",Class="W25X10",Category="FLASH",MFG="PMC",Vcc="3.6V",CodeSize="131072",Adapter="SOIC8-DIP8, ADP-004";
gliga69 Posted - 12/06/2013 : 02:01:17
this line is incorrect:
"Name="PM25LD010",ID="7F9D10",Class="AT25FS010",Category="FLASH",MFG="PMC",Vcc="3.6V",CodeSize="131072",Adapter="SOIC8-DIP8, ADP-004";"
I was try to read "PM25LD010" after the devtxt mod cannot read the chips id. I was able to read and write the chip as w25x10 whit skip id check .
Peter
ZLM Posted - 08/12/2011 : 09:19:37
Add following lines into devices.txt file:
Name="PM25LD512",ID="7F9D05",Class="W25X10",Category="FLASH",MFG="PMC",Vcc="3.6V",CodeSize="65536",Adapter="SOIC8-DIP8, ADP-004";
Name="PM25LD020",ID="7F9D11",Class="AT25FS010",Category="SERIAL_EPROM",MFG="PMC",Vcc="3.6V",CodeSize="262144";
