| T O P I C R E V I E W |
| nyuzva |
Posted - 12/31/2006 : 17:07:21 I have AT25640A EEPROM, but I can"t find it in the list of supported devices of True USB Willem Programmer (GQ-2X). Tried to read AT25640A, using 25C640 from device list with no success. But AT25128A is in that device list. Is there a way to read and write to AT25640A, using True USB Willem Programmer (GQ-2X) and how? Thank you.
| 6 L A T E S T R E P L I E S (Newest First) |
| nyuzva |
Posted - 01/03/2007 : 21:58:39 No, when I am using: Name="AT25640A (Test1)",ID="XXXX",Class="25C020",Category="SERIAL_EPROM",MFG="Atmel",CodeSize="8192";- programmer does not read correctly, I'm getting something like 3 first lines are repeating to the end with some offset. 00 FF C0 EE FC F3 C6 79 64 FF C0 EE FC F3 C6 79 64 FF C0 EE FC F3 C6 79 64 F9 C0 F9 C0 F9 C0 30 38 38 34 30 31 30 37 35 35 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF C0 EE FC F3 C6 79 64 FF C0 EE FC F3 C6 79 64 FF C0 EE FC F3 C6 79 64 F9 C0 F9 C0 F9 C0 30 38 38 34 30 31 30 37 35 35 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF C0 EE FC F3 C6 79 64 FF C0 EE FC F3 C6 79 64 FF C0 EE FC F3 C6 79 64 F9 C0 F9 C0 F9 C0 30 38 38 34 30 31 30 37 35 35 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF C0 EE FC F3 C6 79 64 FF C0 EE FC F3 C6 79 64 FF
It behaving same as when I am selecting 25c640 SPI from the device list.
But when I selected: Name="AT25640A (Test2)",ID="XXXX",Class="AT25128",Category="SERIAL_EPROM",MFG="Atmel",CodeSize="8192";- programmer read EEPROM correctly. I did not try to write yet. |
| ZLM |
Posted - 01/03/2007 : 19:21:25 Do you mean the Test1 works? This? Name="AT25640A (Test1)",ID="XXXX",Class="25C020",Category="SERIAL_EPROM",MFG="Atmel",CodeSize="8192";
| nyuzva |
Posted - 01/03/2007 : 17:22:31 Thank you ZLM.
Name="AT25640A (Test2)",ID="XXXX",Class="AT25128",Category="SERIAL_EPROM",MFG="Atmel",CodeSize="8192"; Name="AT25640A - worked for me nice. |
| ZLM |
Posted - 01/03/2007 : 02:45:22 try those two:
Name="AT25640A (Test2)",ID="XXXX",Class="AT25128",Category="SERIAL_EPROM",MFG="Atmel",CodeSize="8192"; Name="AT25640A (Test1)",ID="XXXX",Class="25C020",Category="SERIAL_EPROM",MFG="Atmel",CodeSize="8192";
| nyuzva |
Posted - 01/01/2007 : 13:00:28 Thank you ZLM for answer. YES, I can read the AT25640A by selecting AT25128A. Can you, please, tell me how to add AT25640A to the list of supported devices? I read the manual about the devices.txt file, tried to add the line for AT25640A, similar to AT25128A, but when I start the program I am getting error and Log file is: #ERROR# Line syntax error: "Name="AT25640A SPI EEPROM",ID="XXXX",Class="AT25640",Category="SERIAL_EPROM",MFG="Atmel";" **** End of log **** Thank you. |
| ZLM |
Posted - 01/01/2007 : 11:06:24 Can you read the AT25640A by selecting AT25128A? If you can partially read/write AT25640A in this way, then you can easily add it. |
