 Help with a EON F80-75HCP on the GQ-4X
teknomedic Posted - 01/07/2012 : 15:34:40
Long story short is that this chip hold the BIOS to a laptop that was incorrctly flashed with the wrong BIOS.
What I need to do is erase and reflash this chip. The problem is that it's an 8 pin surface mount and soldered onto the mainboard so I'll need to make a "wire rig".
I'm hoping that even though I can't seem to find this chip on the master list that I can still get some life out of it... but to do this I could really use some help with figuring out how I should wire the pins. Should I just go Pin 1 to Pin 1... or will I need to do something odd like Pin 1 to Pin 5 etc?
Thanks for any help on this.
osvaldo Posted - 01/19/2012 : 19:20:43
vos la que necesitas grabae es eon25f80-75
ZLM Posted - 01/12/2012 : 20:01:52
no. This chip is not supported on GQ-4X.
teknomedic Posted - 01/08/2012 : 12:48:55
had to edit the subject... seems the BIOS chip is an EON F80-75HCP
