| T O P I C R E V I E W |
| _n3o_ |
Posted - 05/31/2012 : 15:54:55 HI, i have a brand new GQ-3X, i have already burnt 20 EPROMS sucessfully (27c801 and 27c1001) but suddenly , without any particular reason, all the EPROMs programming i have tryed stops at 53%
I have tryed with 8 different EPROMS, restarted my computer, but it's always the same thing.
When it comes to 53% the VPP led goes low and then blink rapidely (here is a video of the led :h**p://youtu.be/LHSNYryrGxQ)
Any idea to solve it ? do i need to change a damaged component (i have skill for it) or do i need to send it back to MCumall ?
Thnaks in advance for your answer |
| 6 L A T E S T R E P L I E S (Newest First) |
| _n3o_ |
Posted - 10/15/2012 : 02:06:33 Thanks for your answer , i'm gonna copy past my previous mail (with all the informations) to this email adress.
Thanks a lot (i've just bought a gq4X from a friend but 2 are betters than 1 ^^)
is it .cm or .com ? i've already emailed .com and they always ask me to do the same test. |
| ZLM |
Posted - 10/13/2012 : 11:37:29 "no answer"? that is not the MCUmall stlye.
Write to support@mcumall.cm with your order number, you can get a replacement if it does not work for you. |
| _n3o_ |
Posted - 10/12/2012 : 05:39:29 up
Asked MCumall ebay webshop for help or warranty = no answer
If you can tell me how to repair it i can certainly do it, but i need to know what to do ! ! Is it a capacitor problem? a memory problem? When i try to burn eproms larger than 512k it fails everytime.
Best regards and please help me ! |
| _n3o_ |
Posted - 06/07/2012 : 14:58:55 after a lot of test, the only thing that i can say it's that now i have a brand new programmer that can only burn eproms under 512k ....\o/ very usefull. thanks for your support .... |
| _n3o_ |
Posted - 06/01/2012 : 01:51:40 Thank for your help ZLM, it reads correctly :/ |
| ZLM |
Posted - 05/31/2012 : 19:57:30 check if programmer read correctly.
If reading is not good, then you need to check all pin contact with the programmer ZIF.
