 ATMEGA Questions
carlsson Posted - 07/01/2012 : 14:23:14
Two questions about ATMEGA chips and the GQ-4X:
1. I have ATMEGA644-20PU in DIP-40. My GQ-4X recognizes ATMEGA644, but only through AVRISP adapter, which I suppose is for PLCC44 chips. Can the software be updated to recognize the chip even in DIP form?
2. While asking, can be software be updated to recognize ATMEGA1284 chips too? I don't know if the programming algorithms differ, but at least the pinout seems to be the same.
dupontg Posted - 08/06/2012 : 12:25:27
hello,
I have tested Atmega8 in DIP28 and QFP32 ,and the ISP does the same job when correctly connected.
You need only a 5VDC power supply between Vss and Vcc
and connect with 5 wires, /RST ,MISO ,MOSI ,SCK and GND from the GQ4X to the pins of the chip.
ZLM Posted - 07/05/2012 : 06:17:54
Try to select ATMEGA128 from software.
