 correct ion mileage
helderchissano Posted - 07/25/2012 : 03:27:23
hi friends i want to know with address i can found the mileage on chip 93c46 or with program can i use to know what is the address of the mileage?
Please my friend help me to understand how to use this tools
Bad_Ad84 Posted - 07/28/2012 : 10:41:31
Windows Calculator will do hex -> decimal and back again
helderchissano Posted - 07/27/2012 : 22:30:09
I think the value is stored somewhere in chip. You need to find it yourself. The stored value should be in hex value format.
Before you remove the chip from your controler, write down the true reading from your dash board. Eg. 135820
Then read the chip by programmer, find the hex value in the code. eg. 02 12 8C is the hex value for 135820
what program can I use to decode hex files to be able to decimal?
because only so I can read and edit my mileage problem and why knowing how to decode it so I can know the address of the mileage and edit without problems, my difficulty is in how to decode how to decode or what program I use.
Best regards
helderchissano Posted - 07/27/2012 : 22:28:43
Best regards
ZLM Posted - 07/25/2012 : 11:22:27
