T O P I C R E V I E W |
cavemann |
Posted - 11/21/2012 : 09:18:55 Hello, A problem today-- Start up software--OK Voltage diagnostic--All OK Blank Check--OK Write--hangs at 0% forever.
Then, I cannot do anything else with program--I can't quit (must restart PC to quit), can't blank check again (hangs), even voltage diagnostic hangs.
I have burned hundreds of EPROMs, no problem, then this problem occurs today. I have made no changes to the PC, no new software or anything else (I only use this PC for burning EPROMS)
Please advise, Thank you.
HW Re: GQ4X Re: 1.40 USB Driver Re 1.0 Software re 6.13 Windows 7
ZLM |
Posted - 11/21/2012 : 12:13:27 It may caused one of the followings:
1. bad chip. Confirm your is a real good one. 2. bad USB connection. Check the USB cable, USB port. Change the USB cable. 3. bad pin contact
